Fehlermeldung im Thread
  • Abarth Forum > 500 Abarth > Technik > Erfahrungsbericht Tuning Pogea Racing
    Kriege Fehlermeldung: Fatal error PHP notice in file:
    Information:
    error message: PHP notice in file /var/www/vhosts/abarth-forum.de/httpdocs/wcf/templates/compiled/224_1_1_licenseplateDE.php (74): Undefined index: district
    error code: 0
    file: /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/system/WCF.class.php (281)
    php version: 5.3.2-1ubuntu4.21
    wcf version: 1.1.10 pl 1 (Tempest)
    date: Thu, 10 Oct 2013 14:15:23 +0000
    request: /modelle/500-abarth-abarth-500c/technik-a500-a500c/erfahrungsbericht-tuning-pogea-racing-t11876/
    referer: http://www.abarth-forum.de/mod…-500c/technik-a500-a500c/
    Stacktrace:
    #0 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/templates/compiled/224_1_1_licenseplateDE.php(74): WCF::handleError(8, 'Undefined index...', '/var/www/vhosts...', 74, Array)
    #1 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/system/template/Template.class.php(267): include('/var/www/vhosts...')
    #2 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/system/template/Template.class.php(397): Template->display('licenseplateDE', false)
    #3 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/system/licenseplate/LicensePlates.class.php(83): Template->fetch('licenseplateDE')
    #4 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/system/licenseplate/LicensePlates.class.php(53): LicensePlates->getHTML('257', 'Center')
    #5 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/system/event/listener/MessageSidebarFactoryLicensePlateListener.class.php(35): LicensePlates->getLicensePlateOutput()
    #6 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/system/event/EventHandler.class.php(207): MessageSidebarFactoryLicensePlateListener->execute(Object(MessageSidebarFactory), 'MessageSidebarF...', 'init')
    #7 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/data/message/sidebar/MessageSidebarFactory.class.php(70): EventHandler::fireAction(Object(MessageSidebarFactory), 'init')
    #8 /var/www/vhosts/abarth-forum.de/httpdocs/lib/page/ThreadPage.class.php(173): MessageSidebarFactory->init()
    #9 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/page/AbstractPage.class.php(90): ThreadPage->readData()
    #10 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/page/AbstractPage.class.php(46): AbstractPage->show()
    #11 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/util/RequestHandler.class.php(64): AbstractPage->__construct()
    #12 /var/www/vhosts/abarth-forum.de/httpdocs/wcf/lib/util/RequestHandler.class.php(92): RequestHandler->__construct('Thread', Array, 'page')
    #13 /var/www/vhosts/abarth-forum.de/httpdocs/index.php(8): RequestHandler::handle(Array)
    #14 {main}
  • nur um es zu bestätigen... ich auch ^^
    ich habe so einen Fehler mal in meinem eigenen Vorstellungsthread verursacht.
    Damals kam es durch dieses Kennzeichenmodul. Ich hatte es ausgeschaltet, dann ging der Thread wieder.
    Vielleicht sollte der letzte Poster im Thread mal sein Kennzeichenmodul abstellen oder korrekt einstellen.
    Achja, damals konnte ich auch keine PN lesen, die waren vom selben Fehler betroffen.
    Eine Mail an Hajö bliebt damals auch unbeantwortet.
    Schönen Gruß
    Helge
    Mein Abarth 500: schwarz, schwarze Rückleuchten, schwarze Seitenblinker, G-Tech GT278, Innenraumleuchte LED "500", Bilstein B14, Powerflex lila rundum, Sturzplatten Hinterachse, Vmaxx BigBrake-Kit, Recaro PolePosition, schwarze Schroth 4-Punkt H-Gurte, Wiechers Clubsport-Bügel, Nankang NS-2R, Assetto Corse Grill
  • Hallo Helge,
    es ehrt dich ja, dass du versuchst den Fehler bei dir zu suchen, aber das war bestimmt nur Zufall.
    Wenn es wirklich an irgendwelchen Nutzereinstellungen liegen würde, dann müsste der Fehler bei allen Threads auftauchen, an welchen sich der Nutzer beteiligt hat.
    Dem ist aber nicht so, ich kann z.B. derzeit die beiden Community-Threads
    • "Unbekannte Abarths auf der Straße gesichtet - wo sind die Fahrer?" sowie
    • "Bekommt man wirklich soviele Blicke"
    nicht zugreifen, ich erhalte immer einen wahnsinnig (mir leider eher weniger) vielsagenden PHP-Fehlercode.
    Die übrigen Threads, in denen sich "Sh3ld0nc00p3r" und "AleAbarth" beteiligt haben, funktionieren hingegen einwandfrei.
    Ich vermute eher, dass die Fehlersuche in PHP bzw. dem Quellcode der Hompage zu schwierig ist, und sich die festgestellten Probleme auf wundersame Weise von alleine erledigen.
    Könnte gefühlt z.B. durch fernverwaltete Werbebanner passieren, wenn diese unsauber programmiert und ungetestet live geschaltet bzw. aktiviert aber an nicht greifbarer Stelle hinterlegt werden.
    Sobald der Banner deaktiviert bzw. im zweiten Fall erreichbar wird, klappt alles als wäre nie etwas geschehen :D
    [Off-Topic]...Das die Werbebanner nicht durchgetestet werden, kannst du z.B. bei den Partnern an TT-Chiptuning erkennen. Dort wird schon länger
    via Banner und Direktlink auf http://www.chiptuining.de (also einfach nur ein "i" zuviel in der URL) verwiesen, was entsprechend zur Fehlermeldung
    (Sever unerreichbar/Seite unbekannt) führt... und scheinbar nicht weiterstört. Ok, das war jetzt gemein, da die meisten dieser Banner nicht
    selbst hinterlegt, sodern via Agentur bzw. Seitens des Partners gestellt werden.[Off-Topic Ende]
    Es dürfte auch nicht wie von Mr. Henry befürchtet am Browser bzw. dessen Cache oder Cookies liegen, da der Fehler grundsätzlich (Safari, Firefox und Internet-Explorer jeweils neuster Fassung, mit und mit ohne Cookies bzw. Cache) und stets reproduzierbar auftritt (solange er auftritt).
    Ich drücke auf alle Fälle die Daumen, dass der Fehler gefunden wird :top:
    Bis dahin bleibt wohl nur abwarten und Abarth fahren... was ja auch nicht das schlechteste ist.
    Tom!
    Einmal editiert, zuletzt von MrHenry20 ()
  • Ich will mal hoffen das mein Thread wieder läuft, habe mir schließlich die Seele aus dem Leib geschrieben. ;)
    A500C mit Pogea Individual Stage1+, Forge WG gelb, FK-Gewindefahrwerk, ATS Streetrally und genug Leistung und Drehmoment (im Moment)
  • Bei mir auch ;( Treffen in Koblenz aber nur die erste Seite!!!!
  • Hallo ihr!
    Ich kann euch bei eurem Problem leider nicht weiterhelfen. Habe jedoch Hajö informiert, der sich das anschauen wird. Ich hoffe, es ist kein allzu großes Problem und ihr habt bald wieder Ruhe damit. Sorry, daß ich es nicht richten kann. Aber mir fehlt der Zugriff in diesen Teil der Datenbank. :(
    Das aber zumindest schon mal vorab als Info, damit ihr wisst, daß wir dran sind.. ^^
  • error message: PHP notice in file /var/www/vhosts/abarth-forum.de/httpdocs/wcf/templates/compiled/224_1_1_licenseplateDE.php (74): Undefined index: district
    Dat is die Fehlermeldung die kommt. ich bin bin kein Experte für PHP aber da steht was von "licenseplateDE.php"
    Sieht für mich nach dem Kennzeichen Modul aus und nicht nach defekter Werbung.
    In dem Betroffenen Pogea Thread hab ich nix gepostet.
    Vg andreas
    Edit: ich glaub das liegt wirklich an nem falsch eingestellten kennzeichnen und jemandem der in allen betroffenen Beiträgen damit unterwegs war.
    Der Koblenz Beitrag geht auch nicht.
    2 Mal editiert, zuletzt von sh3ld0nc00p3r ()
  • Edit: ich glaub das liegt wirklich an nem falsch eingestellten kennzeichnen und jemandem der in allen betroffenen Beiträgen damit unterwegs war.
    Schwer zu sagen. Die Beiträge gehen halt alle, wenn du auf den jeweils letztgenannten Poster klickst und dir dann dessen Beitrag zum Thread anzeigen lässt.
    Das spricht meiner Meinung nach gegen einen ursächlichen Fehler im Kennzeichenmodul, weil dann alle Threads mit Beteiligung desjenigen nicht zu öffnen gehen sollten (egal von welcher Richtung - also Thread-Übersicht bzw. Postings - her kommend).
    Bleibt spannend,
    Tom!
  • :thumbdown: :thumbdown: :thumbdown:
    - 1
    Fatal error: PHP notice in file /var/www/vhosts/abarth-forum.de/httpdocs/wcf/templates/compiled/224_1_1_licenseplateDE.php (74): Undefined index: district
    Information:
    error code: 0
    date: Tue, 15 Oct 2013 14:16:07 +0000
    request: /community/let-s-talk-about/unbekannte-abarths-auf-der-strasse-gesichtet-wo-sind-die-fahrer-t697/?highlight=
    referer: http://www.abarth-forum.de/ind…rm=Search&searchID=484721
    Stacktrace:
    #14 {main}
    Altes Sprichwort in der Emilia romagna ( Italien):
    willst du Glück für einen Abend, betrinke dich,
    willst du Glück für ein Jahr, nimm dir eine neue Frau,
    willst du Glück für ein ganzes Leben, kauf dir einen Abarth.
  • Wir haben es unserem Admin (Hajö) geschrieben, wie MrHenry oben schon gepostet hat.
    Wir hoffen das Problem schnell gelöst zu bekommen...
    nach einiger sucherei habe ich den Fehler finden können.
    Es lag an einem ungültigen Kennzeichen was im Profil eingestellt wurde.
    Das Kennzeichen mit der ID257 hat den Fehler ausgelöst.
    Ich habe nun in der DB alle ungültigen Kennzeichen gelöscht.
    => Danke an Dennis für den Support!
    Nun sollte es keine Fehlermeldeldungen mehr geben.
    Sollte dies doch noch der Fall sein, diese bitte hier rein kopieren.
    Danke für die Infos.
    Hajö :)
  • Hey Leute,
    dieser Fehler tritt beim Anklicken meines Profils auf.
    Bitte um Hilfe....
      (144,25 kB, 255 Mal heruntergeladen, zuletzt: )
  • Servus Leute,
    Habe die gleiche Fehlermeldung im Thread "Treffen in Pforzheim"...
    Weiß jemand woran das liegt ?
    Gruß Tim
    Mein Abarth Punto: Grande Punto, Mazza Stage 2, HRE Krümmer mit EGT, Downpipe mit 70 mm Erweiterung von Gtech und Zeitronix ZT2, IHI Stage 2 mit Billetverdichter, G-Tech GT560RS, K&N57I Performance Ansaugung, HG Ansaugrohr und HG LLK, Bonalume SUV (geschlossen), Oil Catch system (geschlossen), Wavetrac, KW V2, DNA Uniball Domlager
  • Hallo Tim,
    das liegt leider daran, dass immer mal wieder jemand Fehler bei den Kennzeichen machen.
    Und das führt dann leider zu einem Fehler, wenn der betroffen dann postet.
    Um das in den Griff zu bekommen muss ich einen Job manuell laufen lasse, dann gehts wieder.
    Somit auch diesmal wieder bereinigt.
    Hajö
