Its nothing more like a Piggyback Ecu. Your way with standalone is very good!
G-Tech GP/R 500
ben_der: Danke. Und was bringts?
Bessere Füllung vom Zylinder, Besseres ansprechverhalten. -
Im idealfall ja. Ist aber von mehreren Aspekten abhängig. Wenn die Größe des Plenum falsch berechnet oder gebaut ist kann es auch ganz schnell den entgegengesetzten Effekt haben.
We talk about advantages from the ITB. Better fueling and better response is what people expect or think about it. I wrote also that it can happen with a wrong meassured plenum that the engine can have less power.
Hello Lagerlout,
Can you please inform me where did you find this intake manifold? I am interested to get one like this!
cheers,
Fotis -
Intake manifold is custom CNC made for me. You will need to remove the air conditioning if you want to fit a manifold like this. It is custom designed to work with the enlarged cylinder head ports and the ITB's.. You can't really use one without the others..
